Photovision
I’m having an issue with photovision, I connect the raspberry pi to my computer and I search: http://photonvision.local:5800/, but when I search it appears:
Hmm. We’re having trouble finding that site.
We can’t connect to the server at photonvision.local.
If you entered the right address, you can:
Try again later
Check your network connection
Check that Firefox has permission to access the web (you might be connected but behind a firewall)
The green light of the raspberry pi is lightning, I format the raspberry pi and I install again the image of photovision but it doesn’t works.
You can’t connect a pi running Photonvision directly to a pc without a router or a radio in place it may work in some special cases but it is not supported.
