I’m not sure if this is the correct one to place this (or in the program board), but does anyone know of a place where to get a free PHP IDE? I knew of one called dev-php or something like that, but I can’t find the link anymore (if you know where I can find this, please give me the link…I’ve searched Yahoo for this before posting).
Could this be it?
http://devphp.sourceforge.net/ (first result on Google searching for “dev-php”)
*Originally posted by Brian M. *
**Could this be it?
Yes, that is it. Thanks much (/feels I should just use the Google Toolbar instead of the Yahoo one)
*Originally posted by Raven_Writer *
**Yes, that is it. Thanks much (/feels I should just use the Google Toolbar instead of the Yahoo one) **
Google and Yahoo share data. I don’t think it would’ve made a difference.
Search Technology provided by Google
There’s probably other stuff of interest here: PHP: Getting Help
This is just what i have been wanting, but have been too lazy to go out and find. I can stop using notepad now. Thanks!
*Originally posted by Rickertsen2 *
**I can stop using notepad now. Thanks! **
<– prefers wordpad over notepad
*Originally posted by Jack *
**<– prefers wordpad over notepad**
Wordpad is what I used (besides MSVC++ 6 [ha, I’m cheap]). Notepad is great if you hate Wordpad and/or don’t have MSVC++ or another program w/ syntax highlighting (although VC++ doesn’t have the php stuff).
OR use something nice like Jedit (www.jedit.org) which supports syntax highlighting of 80 some languages and support for a plethora of plugins.
http://www.scintilla.org/
does code folding
draws little lines that lines up if brackets, etc
does syntax coloration for more stuff than i knew existed
http://www.chami.com/html-kit/
syntax coloration
far more plugins than you will ever need
http://www.maguma.com/en/lightdownload.html
full blown IDE (does auto-completion for your own classes/functions as well as php’s built in stuff)
syntax coloration (whoo!)
phpdoc support (pops up tooltips, and… eh. similar to javadoc in java)
http://phpeclipse.sourceforge.net/
plugin for eclipse, does same things as maguma, but you get all the power of the eclipse platform
http://www.xored.com/products.php
similar to the above, slightly inferior (IMO), but the two both have slight advantages over the other
there are lots more…
