*A massless spring of free length L and spring constant K is stretched until a desired force F is achieved. A mass M is attached to the stretched spring, and the spring is then allowed to accelerate the mass until the spring length is L2.
Find a closed-form solution for the speed of the mass when the spring length is L2 (where L2>L). Ignore friction and gravity. Use the solution to explore the effect of small changes in L and K (with F, M, and L2 held constant).
Sure. I used a somewhat roundabout method. Let A = F/k be the amplitude of the oscillation. The position will follow simple harmonic motion with equation x = L + A * cos(sqrt(k/m)*t), with x = 0 as the left end of the spring and the mass started at t = 0. So we set x = L2 and so L2-L = A * cos(sqrt(k/m)t). Also, v = x’ = - A * sqrt(k/m) * sin(sqrt(k/m)t). So then we have v^2 = A^2 * (k/m) * sin^2(sqrt(k/m)t) = (k/m) * (A^2- A^2 * cos^2(sqrt(k/m)t)) = (k/m) * (A^2-(L2-L)^2) = ((F^2)/(km) - (k/m)(L2-L)^2). Finally we have
v = sqrt((F^2)/(km) - (k/m)(L2-L)^2).
