pic: 16 Tooth Output Gear With Integral Key
NC Solutions located in Grand Rapids, Michigan has been supporting local area FRC teams for a number of years. They specialize in wire EDM burning and CNC machining operations. They received a RFQ to make 16 tooth, 14.5 PA, 20DP gears with a ½ bore and integral 1/8 key from Boston Gear. For those of you familiar with AM Super Shifters and make your own transmissions, this gear paired with the standard 48 tooth AM SS gear would be a good setup when using 8” direct driven wheels to reduce High FPS.
Contact them at: http://www.ncsolutionsincorporated.com
Or 616-745-4751
Edit: Nevermind, I miss read what this was for.
