very nice wood frame. how much does it weigh?
Oh, NOW I see why you liked my team’s chassis rail.
How’s the traction? Aren’t 8wds so fun to spin with? I might build one in years with no obstacles.
Would you mind mailing me a copy of your chassis? What kind of plywood is that, it looks like you stained it?
Most likely baltic birch. Sean loves that stuff.
Sean, I saw the entire frame/bot, it looks so nasty XD
Are you painting it black later or leaving the stained finish?
Why am I up at 4:45 AM? I can’t fall asleep because our robots are actually “finished.”:yikes: Plus I have to be back at the shop in 3 hours anyway.
Total weight at ship is 113 lbs. It is Baltic birch all laser cut using our tabbed construction method. Traction is excellent with the colsons and with a gearing change already in the works should be a monster. We are also using timing belts in the drivetrain and so far. they are working perfectly
