Brazilian Robot
Very nice looking package. Good luck this year!
That’s some nice machining! =O I especially like the labeling of the Bumper Zone.
Just one little thing. It looks like your drive shafts stick past the frame? I think that was ruled to be in violation of the frame perimeter rules (even if it falls within the 28x38 rules).
I believe those would be considered “minor extrusions”
Yes, but there is no rule that allows minor protrusions to stick out of a vertical projection of the FRAME PERIMETER if they are not inside the BUMPER ZONE.
The frame as pictured, appears like it may have a problem with <R16>
Very nice! … are you guys capable of going under the bump or are you a little too tall?
I like your 6 wheel drive design, and the compact size of your robot suggests that you will be going under the bump, a good plan indeed. All in all, good job!
hello
thanks the replies guys!
the bumper zone has 1/2 inch more than the rest
and the max perimeter is 16’ x 23’ x 31
Water-jet FTW?
laser cut…
Well it was one of the two :rolleyes:
Very nice! That’s one good looking machine right there.
