I do want a water jet also, those parts look pro. they are clean, i am jealous.
Looks VERY familiarā¦:rolleyes:
Laser would only take about 30 minutes to cut all that, and it would not have any draft. But, you would have to deburr.
Nice job looks like you have a lot of welding to do. maybe think about using 3/16 pop rivets in your design next time with an air rivet gun.
Bend flanges on the parts to rivet into.
The welding will weaken the aluminum by taking the hardeness down to T Zero at welds unless you have the frame reaged.
Donāt eat to much of the paste. Even though it tastes good.
My understanding is that some fancy water cutting machines angle the nozzle to compensate for the draft angle. At the very least, that may not be a concern.
Weāve had a lot of āfunā trying to tweak our plasma cutter to produce as little dross and draft as possible. Weāre getting better at it, but itās still frustrating.
the waterjet used on these parts is a 5-axis machine. we programed it one time to blast around 6000 small holes Arround this hemispherical part. but 99% of the time were only using 2 axis like this time. the draft is minimal with aluminum so it can be cleaned up in the important places with a file
