I’m pretty sure it’s named Gene! :eek:
Specifications:
- 6 motor single speed drive, geared for about 11 feet per second
- Cantilevered drive wheels driven by 9mm internal belts
- Arm shoulder joint driven by window motor with custom dogged sprocket for post match reset
- Arm made from 2.5" and 2" PVC - telescopes and locks open at match start to reach all three levels at ideal scoring angles
- Pneumatic pinch claw made from 3/4" baltic birch plywood. Base plate made of sheet aluminium with nylon slider attached for effortless ground pickup.
- Minibot deployment (to be attached) self centers in order to ensure pole contact
- Minibot A climbs in under 4 seconds. Minibot B is to be determined…
Our best robot yet. See you at WPI and Connecticut.
Our preship video will be released sometime in the next 24 hours.
