pic: 294, Bottom view, Hall Effect +-75A Current Sensor PCB asy
Male PWM wires properly re-ordered then
inserted from bottom into outer row holes and soldered.
Male connector is laid flat & cemented to board.
Crimped PWM wire / connector provides reliable strain relief.
Ring terminals bolted to high current eyelets.
Soldering ACS750 heavy connections requires 60W iron.
