pic: 5 Inch Wheel
.5 pounds, 5 inch wheel, machined from a solid block of aluminum. Please leave feedback
The first thing I see missing is no key or bolt pattern for a sprocket.
Ya, I didnt include a keyway but I plan to key this once we make it, if it ever gets made. Can you make keyways on a mill? I dont think you canm but might be wrong… :smiley:
The spokes look nice; but I’m curious if there is any mathematical basis (or any other basis other than artistry) for their shape?
FYI - I have no hidden agenda or Socratic teaching attempt hidden in my question - I am certainly not good enough at mechanical engineering to perform anything other than the grossest levels of analysis to answer a question like the one I just posed.
Instead, each time I see a design like this one posted as a CAD rendering, I am sincerely curious what design guidelines, or computational analysis, or empirical data the author was able to use when creating the design. Yours just happens to be the one that finally got me to ask the question.
What can you tell us?
Blake
I first cut out 5 spokes that went fully from the center to the outside with all inside material cut out. I made them 1/4 inch because I felt that to be plenty to support the wheel. I filletted the edges of the spokes for extra support and thev used cosmosxpress in solidworks to run stress analysis, placing an 120 lb force on an individual wheel supported by the axle. Then after seeing it would not break I cut more weight by adding holes in an artsy way and did more stress analysis. Really I find the best way to make light weight objects is to cut a little weight and then stress test and repete until you are either happy with the weight or unhappy with how strong it is getting. :smiley:
personally i would favor a broached hex to the keyway for strength
mike d
The spoke design is currently inefficient. The force exerted on the spoke via the torque applied at the hub decreases as you get farther away from the hub. So, the spokes should be thicker towards the center and thinner as you get closer to the rim. The holes in the spokes also greatly decrease the strength, If the spokes are strong enough as is with the holes, then I would redo do it with smaller spokes without holes (which if done right would weigh less than the current spoke).
But, overall, a solid start on a wheel design.
Why does torque decrease as you get farther away?
The torque is mainly at the shaft or the middle of the wheel. As you move farther from the center, the torque decreases.
The torque doesn’t change at all, but if you pick a cross section of the spoke, you can say the force on it (from the torque) is the torque divided by how far it is from the center. Think of it as a lever arm, if you apply a torque to the end of it, the force the end of the lever exerts decreases as the lever’s length is increased.
And for what Mike says, YES!!! If you can find a way to use hex axles, do it. They form a stronger connection than a keyed shaft, and are just way easier to work with… On top of that you never have to worry about losing a key, or making them in the first place.
Thanks :smiley: We might go with hex. Is it hard to find hex sprockets and what do you use as bearings with a hex shaft?
pink uses flanged bearings and hex stock from mcmaster carr.
you can put the hex stock in a lathe and turn it under size so the bearing slips on and the remaining hex locates it from side to side
mike d
As Adam said, the force (not the torque) on the spoke decreases as you get farther from the center.
Torque = Force x Distance, so as distance increases, force decreases.
Edit: Beat to it.
Take the hex shaft to a lathe and turn it down to a circle that will fit into a bearing.
EDIT: Mike beat me.
Ya thats our problem, we have a mill but no lathe. We could do it, but it is a huge hassle and we wouldnt have the freedom of doing this in shop… Hopefully we will get one sometime…:smiley:
1323 would machine it out for you if you guys needed, just email me. We machine out parts for teams in need.
unless you would have to chew the shafts with your teeth, it will be worth it compared to keyways, also its a very basic machining practice with a reletivly loose tolerance if you needed to pay someone to machine them for you.
mike d
Thanks, are you in atlanta? We have a source in atlanta but it is just hard to get there and back in traffic, plus if something happens we cant fix it spur of the moment.
No, California.
i would think there would be plenty of shops around atlanta that would be able to do it, if not, I am in florida, send me some dimensions and i will whip them out for you.
mike d
