pic: 775 Pro Two-Speed Gearbox Side
Two-speed gear box using flipped 775pros and a belted first stage
12.15:1 High 19.07 fps adjusted
35.51:1 Low 6.52 fps adjusted
(speeds using 3.5in colson)
View showing vent holes and motor positions for serpentine belt, still missing idler (top right hole)
Looks good. I like the black.
How do you plan to do the serpentine belt? I don’t see it.
Does the larger shifter gear interfere with a sprocket on the output shaft right below it? From the picture it looks like it might happen. Where do the sprockets for a WCD go then?
Referencing your other picture, you have one flipped piston pushing that shifter through a sort of cantilevered linkage. The shifter has unbalanced forces. Don’t trust me, but I remembering hearing that was bad for 192’s 3x flipped CIM gearbox and they ended up using 2 flipped pistons to balance forces on the shifter.
