pic: 926 ON THE BAR
how did you guys make it up the 6 inches with thos tiny wheels?
must be magic, I sure cant see how
Those wheels sure look to be the same size that we’re using.
I can assure you we get onto the step :smiley:
Cory
are they spaced that far apart?
Approximately the same, yes, although a bit closer together, maybe
Cory
then how do you do it my fine friend. How do you prevent bottoming out
momentum…
The chassis looks fairly high compared to the wheels too.
My guess is that they went up the small steps and around the goal. Then pulled themselves up from there.
Good job! We’re also using pnuematics to pull ourselves up. Our compressor runs quite a bit but our pnuematics have worked flawlessly so far.
