"In the case where the Match score of each Alliance is equal, the tie will be broken by awarding an extra point to the Alliance with the highest number of Foul points granted (the Alliance that played the cleaner Match). If both Alliances have the same number of Foul points, the extra point will be awarded to the Alliance with the highest Hybrid points. If both Alliances have the same Hybrid score, the extra point will be awarded to the Alliance with the most Bridge points. If both Alliances scored the same number of Bridge points, the match is considered truly tied and will be replayed if needed.
In this match, both teams had the same number of foul points, hybrid points, bridge points, AND tele-op points. The number 7 alliance drew the quarterfinals at Detroit into an epic 4th match. Congrats to the 2nd alliance for pulling ahead, but I also congratulate the 7th alliance for putting up a very good fight.
