Well, I talked to AndyMark about using the Floating Zip Tie Chain Tensioner Idea created by me; found in this thread: pic: Floating Zip Tie Chain Tensioner - CD-Media: Photos - Chief Delphi. AndyMark agreed and now this will be available before the season starts and I would like to thank everyone for helping me in the design. Also thanks CD for urging me to market this idea.
I understood the original concept, but what are the curved up tabs sticking out the sides for in this design?
I will refrain from my next comment about those tabs before I hear their purpose, since I assume they have one.
We’ll definitely be buying them. Only worry that comes to mind is if there’s enough material to take the wear and tear without “wearing through”? The tensioners we made ourselves out of Delrin probably had a 1/2" of solid backing and I’ll bet we wore through 1/8" of it. Looks like there might only be 1/8" there, but it’s hard to tell w/o dimensions. Have you done any testing on wear?
not in all cases. standard uhmw is around 66 shore D while Delrin is around 86 shore D
Since these are both plastics which can contain glass filling, other materials, recycled plastic it is not wise to make generalizations about materials. Especally in this case where you didn’t state the exact material which these are molded and the exact type of delrin they used.
On another note, I am not sure that hardness is the correct measure for effective chain tensioners. I would think it has to do with the lubricity of the material and the ductility. While hardness probably comes into play (ie why gum rubber wouldn’t be a good tensioner) It is not the only (or possibly the main one) which needs to be considered.
