Found an excellent use for Armabot Right Angle Dive gearbox, an alternative to a battery powered drill to make shafts spin. FRC legal motors can be installed on the VersaPlanetary, different ratios can be tested and in our case no more breaking the magnet off the long AM Toughbox output shaft when using it with a drill motor. To facilitate easy on and off ThunderHex shafting, the ½” bearing is now retained directly to the housing, no messing with internal spacers.
