pic: ball laucher
this is when it shook itself to pieces!!!
Don’t these small wheel demolish the ball?
They are six inches, I believe, same as our drive wheels, so not that small. We had no trouble with the wheels demolishing balls though. There isnt a whole lot of compression on them.
Hey, what part did you use to connect those wheels to the shaft of the CIM motor?
http://www.chiefdelphi.com/forums/showthread.php?p=447619#post447619
There is a drawing here… and they are soft rubber, so there is NO problem tearing up the balls :slight_smile:
go to McMaster and type in 2469k2, would that work? or would i rip up in place? :confused:
I would use the keyed one, or add a setscrew for each shaft, but yeah… That would probably work quite well :slight_smile:
