pic: FRC Stronghold Basic Scouting Sheet
A basic visual scouting sheet for FRC Stronghold. Not intended to be for thorough analysis, just for gathering basic data that we will see on a regular basis. Should anyone want to use it, no credit is required.
Wouldn’t it be a good idea to track the full number of crossings a robot does, since their most common defenses give a lot of insight into choosing a defensive strategy.
Wouldn’t you also want to add a section where scouts can indicate whether or not the robot was able to successfully park on the batter? Knowing this would be good for your scouting team because I foresee teams not fitting or not having the proper wheels to capture the tower (without climbing).
This may be a bit difficult, but if I were you, I’d want to know what a team does in Auto. If they have a complex auto routine that can score us points but requires they go through a certain obstacle (ex. the low bar), I’d want to know about it.
