pic: HF 10" wheel
Side view of the mounting, in this picture you can see the 3/16" steel flange and the screws holding the sprocket on the flange.
so you welded a plate drilled for the sprocket onto the wheel hub? Are you still able to remove the bearing? What chain pitch is that, looks like #40 - Bike chain.
