This is the game field for the 2009 Midwest Vex Programs Challenge: High Jacked. 25 whiffle softballs line each long edge of the pit. The pit is formed by a 24" wide 2.125" high platform around the perimeter of the field. In two corners are a valley (where balls are scored for points) and the other two corners are mountains, where the Jacks are scored. The Not-So-Shybot in the middle is an autonomous 7th robot on the field that will bounce around and create havoc. It also possesses the two bonus balls that can be released by introducing the Jacks into play. More info, including animations, is available at www.midwestvex.org.
