One of 1885’s design gems this season. It held up through DCMP 19 matches with no signs of wear. We didn’t want to 3D print a pulley since we didn’t want the pulley shattering during rough play.
Roller is 0.5" ID polyurethane on a 0.5" OD aluminum tube and sits on the outer-most part of our dual-wheel active gear intake… Motor/gearbox setup is a 775Pro through a 5:1 VP. Roller is supported via R6 bearings in 1x1 thick-wall box. Roller isn’t precision-aligned parallel to the VP gearbox, but with this setup it doesn’t have to be. Required tension is “about precise” center-to-center for typical 5mm HTD.
