pic: Off season rebuild 2
This is a picture of where the 3 cim gear box attaches to the frame. we had the bearing which has already been replaced here blow out and as you can see the large 3rd stage gear ground against the frame for some time. However, if you look closely 3 of the six holes around the bearing hole have been filled with metal, as it turns out these are ball bearings from the original bearing that blew out.
