Use this part to streamline your FIRST Robotics Competition Gearbox design. This one model has every gear that West Coast Products sells. Just download the file and add it to your library, then when you want to insert a gear into an assembly just select the part and drop it in. You will be prompted to select which gear you desire. No more looking through all of your files to find the correct gear. You can download the part from 3D content central.
http://www.3dcontentcentral.com/parts/download-Part.aspx?id=376143&catalogid=171
