pic: Team 61 robot week 3
Control systems
Very nice work. I would be worried about the input on that bottom solenoid. That tight of a bend will eventually cause a leak.
Looks “ruggedly” clean. I have to agree with IndySam in the fact that you want to try to get a bigger radius of a bend out of those Pneumatic tubes in the solenoid as the tight bend could cause air flow issues and eventually cause a leak if jostled too many times.
Why isn’t the PDP plugged into CAN?
This board is the proto type will be replace with clear board. Just getting the layout. Thanks for the commits
