PID controller not working
I am trying to use a PID command to get our robot to rotate so our vision target is centered on our camera, however, when run our PID command the output is always 0
here is our code if anyone knows how to fix this help would be appreciated
/* Copyright (c) 2019 FIRST. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package frc.robot.commands;
import edu.wpi.first.wpilibj.controller.PIDController;
import edu.wpi.first.wpilibj2.command.PIDCommand;
import frc.robot.RobotContainer;
import edu.wpi.first.wpilibj.smartdashboard.*;
// NOTE:  Consider using this command inline, rather than writing a subclass.  For more
// information, see:
// https://docs.wpilib.org/en/latest/docs/software/commandbased/convenience-features.html
public class VisionRotate extends PIDCommand {
   * Creates a new VisionRotate.
  public VisionRotate() {
    super(
        // The controller that the command will use
        new PIDController(1, 0, 0),
        // This should return the measurement
        () -> RobotContainer.vision.getCenter(),
        // This should return the setpoint (can also be a constant)
        () -> 0,
        // This uses the output
        output -> {
          SmartDashboard.putNumber("pidoutput", output);
        getController().enableContinuousInput(-.3, .3);
        getController().setTolerance(.005);
    // Use addRequirements() here to declare subsystem dependencies.
    // Configure additional PID options by calling `getController` here.
  // Returns true when the command should end.
  @Override
  public boolean isFinished() {
    if (RobotContainer.vision.getCenter() > .005 & RobotContainer.vision.getCenter() < -.005) {
      return false;
    } else {
      return true;
A few things:
  1. isFinished can be simplified to return Math.abs(RobotContainer.vision.getCenter) > 0.5;
  2. What exactly is the measurement from vision.getCenter()? By the way you are using it, it should be the angle difference from the middle.
  3. Where are you outputting the values?
