I want to create a command that uses pid with a ultrasonic sensor to drive forward a distance i set. I looked into some example code and i made one of my own. I am using the command based robot with robot builder. Keep in mind i have no prior knowledge of pid controllers so if it wrong dont be surprised.
The Code is below in a command
package org.usfirst.frc5713.BuckyBot.commands;
import org.usfirst.frc5713.BuckyBot.Robot;
import edu.wpi.first.wpilibj.PIDController;
import edu.wpi.first.wpilibj.PIDOutput;
import edu.wpi.first.wpilibj.PIDSource;
import edu.wpi.first.wpilibj.PIDSourceType;
import edu.wpi.first.wpilibj.command.Command;
/** This Class drive the robot forward using a rangefinder a set distance you determine
public class SetDistanceToPeg extends Command {
private PIDController pid;
public SetDistanceToPeg(double distance) {
requires(Robot.driveTrain);
pid = new PIDController(-2, 0, 0, new PIDSource() {
PIDSourceType m_sourceType = PIDSourceType.kDisplacement;
@Override
public double pidGet() {
return Robot.driveTrain.getDistanceToObstacle();
@Override
public void setPIDSourceType(PIDSourceType pidSource) {
m_sourceType = pidSource;
@Override
public PIDSourceType getPIDSourceType() {
return m_sourceType;
}, new PIDOutput() {
@Override
public void pidWrite(double d) {
Robot.driveTrain.drive(d, d);
pid.setAbsoluteTolerance(0.01);
pid.setSetpoint(distance);
// Called just before this Command runs the first time
@Override
protected void initialize() {
// Get everything in a safe starting state.
Robot.driveTrain.reset();
pid.reset();
pid.enable();
// Make this return true when this Command no longer needs to run execute()
@Override
protected boolean isFinished() {
return pid.onTarget();
// Called once after isFinished returns true
@Override
protected void end() {
// Stop PID and the wheels
pid.disable();
Robot.driveTrain.drive(0, 0);
