I’m a bit new to coding and been trying to figure out the PID/ encoder for the past hour on my test board. What I want to happen is a smooth motor running and for me to press one button then automatically it would run 200 or so rotations…
This is what it looks like rn:
My Code is:
package frc.robot;
import com.revrobotics.CANEncoder;
import com.revrobotics.CANPIDController;
import com.revrobotics.CANSparkMax;
import com.revrobotics.CANSparkMaxLowLevel.MotorType;
import com.revrobotics.ControlType;
import edu.wpi.first.networktables.NetworkTable;
import edu.wpi.first.networktables.NetworkTableEntry;
import edu.wpi.first.networktables.NetworkTableInstance;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.Spark;
import edu.wpi.first.wpilibj.SpeedControllerGroup;
import edu.wpi.first.wpilibj.XboxController;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
private DifferentialDrive m_myRobot;
// private SpeedControllerGroup m_leftDrive;
// private SpeedControllerGroup m_rightDrive;
private static final int leftDeviceID = 1;
private static final int rightDeviceID = 2;
private static final int leftDeviceID2 = 4;
private static final int rightDeviceID2 = 5;
private static final int liftDeviceID = 3;
private static final int intakeliftDeviceID = 6;
private CANSparkMax m_leftMotor;
private CANSparkMax m_rightMotor;
private CANSparkMax m_liftMotor;
private CANSparkMax m_leftMotor2;
private CANSparkMax m_rightMotor2;
private CANSparkMax m_intakeliftMotor;
private CANEncoder m_liftEncoder;
private Spark intake;
private XboxController gamePad;
private XboxController gamePad2;
private CANPIDController m_pidController;
public double kP, kI, kD, kIz, kFF, kMaxOutput, kMinOutput;
private DoubleSolenoid SmolBoi;
private DoubleSolenoid BigBoi;
@Override
public void robotInit() {
m_leftMotor = new CANSparkMax(leftDeviceID, MotorType.kBrushless);
m_rightMotor = new CANSparkMax(rightDeviceID, MotorType.kBrushless);
m_leftMotor2 = new CANSparkMax(leftDeviceID2, MotorType.kBrushless);
m_rightMotor2 = new CANSparkMax(rightDeviceID2, MotorType.kBrushless);
m_liftMotor =new CANSparkMax(liftDeviceID, MotorType.kBrushless);
m_liftEncoder = m_liftMotor.getEncoder();
m_intakeliftMotor= new CANSparkMax(intakeliftDeviceID, MotorType.kBrushless);
SpeedControllerGroup m_left = new SpeedControllerGroup(m_leftMotor, m_rightMotor);
SpeedControllerGroup m_right = new SpeedControllerGroup(m_leftMotor2, m_rightMotor2);
m_myRobot = new DifferentialDrive(m_left, m_right);
intake = new Spark(0);
SmolBoi = new DoubleSolenoid(0, 2);
BigBoi = new DoubleSolenoid(1, 3);
gamePad = new XboxController(0);
gamePad2 = new XboxController(1);
m_pidController = m_liftMotor.getPIDController();
// PID coefficients
kP = 0.09;
kI = 0;
kD = 0.03;
kIz = 0;
kFF = 0;
kMaxOutput = 1;
kMinOutput = -1;
// set PID coefficients
m_pidController.setP(kP);
m_pidController.setI(kI);
m_pidController.setD(kD);
m_pidController.setIZone(kIz);
m_pidController.setFF(kFF);
m_pidController.setOutputRange(kMinOutput, kMaxOutput);
// display PID coefficients on SmartDashboard
SmartDashboard.putNumber("P Gain", kP);
SmartDashboard.putNumber("I Gain", kI);
SmartDashboard.putNumber("D Gain", kD);
SmartDashboard.putNumber("I Zone", kIz);
SmartDashboard.putNumber("Feed Forward", kFF);
SmartDashboard.putNumber("Max Output", kMaxOutput);
SmartDashboard.putNumber("Min Output", kMinOutput);
SmartDashboard.putNumber("Set Rotations", 0);
// camera
NetworkTable table = NetworkTableInstance.getDefault().getTable("limelight");
NetworkTableEntry tx = table.getEntry("tx");
NetworkTableEntry ty = table.getEntry("ty");
NetworkTableEntry ta = table.getEntry("ta");
// post to smart dashboard periodically
SmartDashboard.putNumber("LimelightX", 0);
SmartDashboard.putNumber("LimelightY", 0);
SmartDashboard.putNumber("LimelightArea", 0);
// read values periodically
double x = tx.getDouble(0.0);
double y = ty.getDouble(0.0);
double area = ta.getDouble(0.0);
@Override
SmartDashboard.updateValues();
// encoders
SmartDashboard.putNumber("Encoder Position", m_liftEncoder.getPosition());
SmartDashboard.putNumber("Encoder Velocity", m_liftEncoder.getVelocity());
m_myRobot.setSafetyEnabled(false);
// Tank drive controlled with the left and right joysticks of the gamepad
m_myRobot.tankDrive(-gamePad.getRawAxis(3), -gamePad.getRawAxis(1));
// Intake
if (gamePad.getRawButton(8)) {
m_intakeliftMotor.set(1);
else if (gamePad.getRawButton(6)) {
m_intakeliftMotor.set(-1);
else {
m_intakeliftMotor.set(.25);
// Elevator Lift
if (gamePad2.getRawButton(6)) {
m_liftMotor.set(0.5);
else if (gamePad2.getRawButton(5)) {
m_liftMotor.set(-0.5);
else{
m_liftMotor.set(0);
//Heigh Button low
if (gamePad2.getRawButton(1)) {
m_pidController.setReference(200, ControlType.kPosition);
else {
m_liftMotor.set(0);
// Height Button med
if (gamePad2.getRawButton(3)) {
m_pidController.setReference(300, ControlType.kPosition);
else {
m_liftMotor.set(0);
// Height Button high
if (gamePad2.getRawButton(4)) {
m_pidController.setReference(400, ControlType.kPosition);
else {
m_liftMotor.set(0);
//intake’s Lift
if (gamePad.getRawButton(9)) {
intake.set(-0.5);
} else if (gamePad.getRawButton(10)) {
intake.set(0.5);
} else {
intake.set(0);
// Breaking System According to the Binder
if (gamePad.getRawButton(1)) {
SmolBoi.set(DoubleSolenoid.Value.kForward);
else if (gamePad.getRawButton(4)) {
SmolBoi.set(DoubleSolenoid.Value.kReverse);
//big boi breaking system
if (gamePad.getRawButton(2)) {
BigBoi.set(DoubleSolenoid.Value.kForward);
else if (gamePad.getRawButton(3)) {
BigBoi.set(DoubleSolenoid.Value.kReverse);
// read PID coefficients from SmartDashboard
double p = SmartDashboard.getNumber("P Gain", 0);
double i = SmartDashboard.getNumber("I Gain", 0);
double d = SmartDashboard.getNumber("D Gain", 0);
double iz = SmartDashboard.getNumber("I Zone", 0);
double ff = SmartDashboard.getNumber("Feed Forward", 0);
double max = SmartDashboard.getNumber("Max Output", 0);
double min = SmartDashboard.getNumber("Min Output", 0);
double rotations = SmartDashboard.getNumber("Set Rotations", 0);
// controller
if((p!=kP)) {
m_pidController.setP(p);
kP = p;
if((i!=kI)) {
m_pidController.setI(i);
kI = i;
if((d!=kD)) {
m_pidController.setD(d);
kD = d;
if((iz!=kIz)) {
m_pidController.setIZone(iz);
kIz = iz;
if((ff!=kFF)) {
m_pidController.setFF(ff);
kFF = ff;
if((max!=kMaxOutput)||(min!=kMinOutput)) {
m_pidController.setOutputRange(min, max);
kMinOutput = min;
kMaxOutput = max;
SmartDashboard.putNumber("SetPoint",rotations);SmartDashboard.putNumber("ProcessVariable",m_liftEncoder.getPosition());
