Hello, I am trying to set up a PID loop where I can tell my drive motors to move the robot at a certain velocity. I am using encoders to measure my current velocity, and I want to set up a PID loop to bridge the two.
I don’t know how to set it up, but I will show what I have so far. I’ve cut it down to show only the left half of the drive train. We call the drive function to give it a throttle amount where 1 is max speed. Could somebody give example code, or correct my mistakes here so I can fix it?
Thanks!
DriveTrain.java:
public class DriveTrain extends Subsystem {
private Encoder leftEncoder;
private PIDController leftPID;
public DriveTrain() {
VictorSP frontLeft = new VictorSP(DRIVE_PORT_FRONT_LEFT);
VictorSP rearLeft = new VictorSP(DRIVE_PORT_REAR_LEFT);
double p = 1.0;
double i = 0;
double d = 0;
leftEncoder = new Encoder(DRIVE_PORT_FRONT_LEFT, DRIVE_PORT_REAR_LEFT);
leftEncoder.setDistancePerPulse((8 * Math.PI) / 360);
leftEncoder.setPIDSourceType(PIDSourceType.kRate);
leftPID = new PIDController(p, i, d, leftEncoder, new DualMotorPID(frontLeft, rearLeft));
leftPID.setOutputRange(-.5, .5);
leftPID.setContinuous(true);
leftPID.enable();
public void initDefaultCommand() {
setDefaultCommand(new TeleOpDrive());
public void drive(double moveValue, double rotateValue) {
//Copied from RobotDrive::arcadeDrive
double leftMotorSpeed, rightMotorSpeed;
if (moveValue > 0.0) {
if (rotateValue > 0.0) {
leftMotorSpeed = moveValue - rotateValue;
rightMotorSpeed = Math.max(moveValue, rotateValue);
} else {
leftMotorSpeed = Math.max(moveValue, -rotateValue);
rightMotorSpeed = moveValue + rotateValue;
} else {
leftMotorSpeed = -Math.max(-moveValue, rotateValue);
rightMotor
} else {
rightMotorSpeed = -Math.max(-moveValue, -rotateValue);
leftPID.setSetpoint(leftMotorSpeed);
and DualMotorPID.java This lets us control two mechanically bound motors with one PID
public class DualMotorPID implements PIDOutput{
private SpeedController motorA;
private SpeedController motorB;
public DualMotorPID(SpeedController a, SpeedController b){
motorA = a;
motorB = b;
@Override
public void pidWrite(double output) {
motorA.set(output);
motorB.set(output);
