PID TrapezoidProfile going backwards on random times
Hello, ever since we started using the arm of our robot with the TrapezoidProfile, it has been going backwards at random times with no apparent reason, it fixes itself after doing a power cycle or deploying the code , we are using 2 NEO motors and a CAN encoder for the arm.
Here is our arm subsystem, if you need to see more of our code to see the problem, please let us know.
package frc.robot.subsystems;
import com.ctre.phoenix6.configs.CANcoderConfiguration;
import com.ctre.phoenix6.hardware.CANcoder;
import com.ctre.phoenix6.signals.AbsoluteSensorRangeValue;
import com.ctre.phoenix6.signals.SensorDirectionValue;
import com.revrobotics.CANSparkMax;
import com.revrobotics.CANSparkBase.IdleMode;
import com.revrobotics.CANSparkLowLevel.MotorType;
import edu.wpi.first.math.controller.ArmFeedforward;
import edu.wpi.first.math.controller.ProfiledPIDController;
import edu.wpi.first.math.trajectory.TrapezoidProfile;
import edu.wpi.first.math.util.Units;
import edu.wpi.first.wpilibj.DutyCycleEncoder;
import frc.robot.Constants.ArmConstants;
import team4400.Util.Interpolation.InterpolatingDouble;
import team4400.Util.Interpolation.InterpolatingTreeMap;
import edu.wpi.first.wpilibj2.command.Command;
import edu.wpi.first.wpilibj2.command.Commands;
import edu.wpi.first.wpilibj2.command.ProfiledPIDSubsystem;
/** A robot arm subsystem that moves with a motion profile. **/
 * Why not use Rev's motion profiling if we have Neo 500 motors?
 * Well we have an Absolute Encoder that returns the current Arm angle but is not connected to the
 * Spark Max data port but to the RoboRIO DIO port 2, so we decided that it was better to use the
 * ProfiedPIDSubsystem class for our Arm so we can have a Motion Profiling PID with the absolute
 * Encoder as a feedback Device.
public class ArmSubsystem extends ProfiledPIDSubsystem {
  private final CANSparkMax leftMotor = new CANSparkMax(ArmConstants.LEFT_ARM_ID, MotorType.kBrushless);
  private final CANSparkMax rightMotor = new CANSparkMax(ArmConstants.RIGHT_ARM_ID, MotorType.kBrushless);
  /*private final DutyCycleEncoder m_encoder =
      new DutyCycleEncoder(ArmConstants.ABSOLUTE_ENCODER_PORT);*/
  private final CANcoder m_encoder = new CANcoder(ArmConstants.ABSOLUTE_ENCODER_ID, "rio");
  CANcoderConfiguration encoderConfig = new CANcoderConfiguration();
  private final ArmFeedforward m_feedforward =
      new ArmFeedforward(
          ArmConstants.kS, ArmConstants.kG,
          ArmConstants.kV, ArmConstants.kA);
          private TrapezoidProfile.State m_tpState = new TrapezoidProfile.State(0.0, 0.0);
  static InterpolatingTreeMap<InterpolatingDouble, InterpolatingDouble>
    kDistanceToArmAngle = new InterpolatingTreeMap<>();
  static{ //Added offset of 5 degrees of all angles because of mechanical problems
    kDistanceToArmAngle.put(new InterpolatingDouble(1.66),  new InterpolatingDouble(160.0));
    kDistanceToArmAngle.put(new InterpolatingDouble(2.05),  new InterpolatingDouble(153.0));
    kDistanceToArmAngle.put(new InterpolatingDouble(2.66),  new InterpolatingDouble(143.5));
    kDistanceToArmAngle.put(new InterpolatingDouble(3.50),  new InterpolatingDouble(138.0));
    kDistanceToArmAngle.put(new InterpolatingDouble(4.15),  new InterpolatingDouble(135.0));
    kDistanceToArmAngle.put(new InterpolatingDouble(4.35),  new InterpolatingDouble(134.0));
  boolean onTarget;
  double akP = 0.32, akI = 0.42, akD = 0.0039;
  /** Create a new ArmSubsystem. */
  public ArmSubsystem() {
    super(
        new ProfiledPIDController(
            ArmConstants.kP,
            ArmConstants.kI,
            ArmConstants.kD,
            new TrapezoidProfile.Constraints(
                ArmConstants.kMaxVelocityRadPerSecond,
                ArmConstants.kMaxAccelerationMetersPerSecondSquared)),
        95.0);
    //Makes the Arm absolute Encoder return every rotation as angles
    //Check encoder direction
    encoderConfig.MagnetSensor.SensorDirection = SensorDirectionValue.Clockwise_Positive;
    encoderConfig.MagnetSensor.AbsoluteSensorRange = AbsoluteSensorRangeValue.Unsigned_0To1;
    encoderConfig.MagnetSensor.MagnetOffset = 0.0;
    m_encoder.getPosition().setUpdateFrequency(100);
    m_encoder.getConfigurator().apply(encoderConfig);
    //m_encoder.setPosition(0.4);
    // Start arm at rest in neutral position
    setGoal(90.3);
    //   this.m_controller.setIZone(20);
    leftMotor.restoreFactoryDefaults();
    rightMotor.restoreFactoryDefaults();
    leftMotor.setInverted(true);
    rightMotor.follow(leftMotor, true);
    leftMotor.setSmartCurrentLimit(80);
    rightMotor.setSmartCurrentLimit(80);
    leftMotor.setCANTimeout(0);
    rightMotor.setCANTimeout(0);
    rightMotor.setIdleMode(IdleMode.kBrake);
    leftMotor.setIdleMode(IdleMode.kBrake);//change do break
    SmartDashboard.putNumber("Arm kP", akP);
    SmartDashboard.putNumber("Arm kI", akI);
    SmartDashboard.putNumber("Arm kD",akD);
  @Override
  public void periodic() {
      super.periodic();
      SmartDashboard.putNumber("Arm Angle", getMeasurement());
      SmartDashboard.putBoolean("Over Angle", overAngle());
      SmartDashboard.putBoolean("ArmEnabled", this.m_enabled);
      SmartDashboard.putNumber("Arm SetPoint Pos", this.getController().getSetpoint().position);
      SmartDashboard.putNumber("Arm Pose Error", this.getController().getPositionError());
      double akP = SmartDashboard.getNumber("Arm kP", ArmConstants.kP),
             akI = SmartDashboard.getNumber("Arm kI", ArmConstants.kI),
             akD = SmartDashboard.getNumber("Arm kD", ArmConstants.kD);
      if (ArmConstants.kP != akP) {ArmConstants.kP = akP; getController().setP(akP);}
      if (ArmConstants.kI != akI) {ArmConstants.kI = akI; getController().setI(akI);}
      if (ArmConstants.kD != akD) {ArmConstants.kD = akD; getController().setD(akD);}
  @Override
  public void useOutput(double output, TrapezoidProfile.State setpoint) {
    // Calculate the feedforward from the sepoint
    double feedforward = m_feedforward.calculate(setpoint.position, setpoint.velocity);
    // Add the feedforward to the PID output to get the motor output
    leftMotor.setVoltage(output + feedforward);
  @Override
  public double getMeasurement() {
    //Minus 70.5 because that gives us a range betwueen 0-180 degrees, 0 being the left position
    //and 180 the right position while 90 degrees is the idle vertical position
    return (m_encoder.getAbsolutePosition().getValueAsDouble() * 360) - 153;
  public double getAngleForDistance(double distance){
    return kDistanceToArmAngle.getInterpolated(
        Math.max(Math.min(distance, 4.35 ), 1.66))).value;
  public Command goToPosition(double position){
    Command ejecutable = Commands.runOnce(
                  this.setGoal(position);
                  this.enable();
                this);
    return ejecutable;
  public boolean overAngle(){
    if(this.m_enabled && (getMeasurement() > 181 || getMeasurement() < 89)){
      return true;
    } else {
      return false;
  public void safetyDisable(){
    if(overAngle()){
      this.disable();
  //For use in autonomous methods to shoot after the Arm is in position
  public boolean isWithinThreshold(double value, double target, double threshold){
    return Math.abs(value - target) < threshold;
  public boolean isInPosition(){
    return isWithinThreshold(getMeasurement(), getController().getGoal().position, ArmConstants.ARM_THRESHOLD);
  public void updateArmSetpoint(double setpoint){
    m_tpState.position = Units.degreesToRadians(setpoint);
    setGoal(setpoint);
It’s possible the setpoint (intermediate position targets to the goal) are at values that don’t match the current position. This causes the generated motion profile to start at a different position that the actual measured position, which could look like the mechanism going “backward” to chase the setpoint at the wrong spot.
To fix this, try adding a this.reset(getMeasurement()) once before each time a new goal is set.
