Piston usage?
How would I go about using a double solenoid to extend and retract a piston. I was able to extend it but I cannot retract it.
Here’s a good instructable: https://www.instructables.com/id/How-to-Create-a-Pneumatic-System-for-FIRST-Robots/
Ignore the part about the SPIKE relay, as that’s legacy hardware. If you have it wired up right, it might actually be a programming issue, I know we’ve had that happen to us in programming before
Just a hint…you’re extending and retracting a ‘cylinder’. The “piston” is the thing inside the cylinder moving back and forth.
Sometimes using the right words is helpful.
There are 2 screws on the inside that you have to manually set for the air flow through the solenoid
Hi Daniel,
Without verifying your system is plumbed correctly myself (or programmed correctly by someone who isn’t me), these are two things I would check:
  • Solenoid voltage - A mistake some people make is running a 24V solenoid valve at 12V. Sometimes valves will still switch at a lower operating voltage, but reliability will be compromised. If the valve’s LEDs are changing but the actuator isn’t moving, this is a likely culprit. Make sure the PCM is set up appropriately for the voltage of the solenoid.
  • Manual overrides - If you can get the valve to change state (and therefore move the actuator) by using the manual overrides on the valve body, then it probably points to a control issue (programming issue, incorrect voltage on PCM) and not something physically wrong with the system. Also double check to make sure manual overrides aren’t locked into a position preventing the valve from shifting electronically.
These are relatively common and easy-to-overlook issues. If you could provide some pictures of the system itself that may help too.
Thanks all for your help! Programming errors earlier on were due to electrical telling me the wrong ports(I should’ve checked) but when I get into our shop next I will definitely be able to test some of these suggestions out! I was just testing using a battery at the time of the post.
