Plastic Mounting
Can plastic be used to mount battries and motors on the robot.
REPLY !!
Man, so far all of your questions are easily awnswered by the manual
Here is the info straight from it:
Fasteners
Fasteners, Washers, Nuts, Adhesives Any amount/size
Joining Plates for Extrusions Any amount, Any size
5 Minute Epoxy Gel
Rubber Band, Large 3-1/2” x 1/4” wide, Up to 5
Hose Clamps Any Ø, Any amount
Pipe fittings (tees, reducers, elbows,
angles)
Any amount - to join sections of pipe
Rubber Band, Small 3-1/2” x 1/8” wide, Up to 5
Pipe Endcaps Any amount - if used to cap pipes
Pipe flanges Any amount - if used to attach pipes
*Originally posted by schitnis *
**Can plastic be used to mount battries and motors on the robot.
REPLY !! **
You can use plastic if the plastic you use has the strength to do the job.
The fact is, you have permission to use anything legal, as Jordan points out.:cool:
Thanks guys
Regards
schitnis
Team 915
