Reticently got LabVIEW working at home and have been playing around with it since I rarely worked outside the WPI library – aside from the basics. So i opened up some examples and mashed them together in order to learn.
On one of them, I created this under the plant PID example: State machine that waits for 2 osculations above the set-point (it misses sometimes), then it’s supposed to create an array of errors and then take the maximum, and if that value is within the set tolerance, and it was all done in less than the settling time asked (delay messes timing too), a boolean labeled tuned would go on and the settling time would be recorded.
The problem is the array part: http://i53.tinypic.com/10xadco.jpg
I’m probably doing something wrong here but is there a way to get arrays to update in real-time. Also, is there a way to program: return true or false based on whether a bolean statement has remained true or false for a certain period of time.
