PlayingWithFusion TOF Can Devices
In the past we’ve successfully used the playing with fusion lidar sensor for various tasks. I thought you used to he able to see it in the Phoenix Tuner and assign the ID but maybe i’m wrong!
I’ve saw in the manual that there is a web based utility.hosted on the rio that allows you to assign the can device id.
Has anyone used this utilitiy recently? I cant seem to access it. I could have sworn in prior years the device would appear in the phoenic tuner (same with the rev power distrribution hub, but maybe my memory.is failing me)
Even if you see it listed in Phoenix Tuner or Rec Hardware Client, you won’t be able to configure anything anyway.
I’m convined i use to be able to. But makes sense.
Has anyone had any success with any other sort of utility?
@joemost I’m sorry i missed seeing this post earlier. Are you still having trouble accessing the PlayingWithFusion configuration page on port 5812 or the roboRIO? We just release version 2024.03.09 of our libPlayingWithFusion library. If you’re still having trouble, grab the most recent version of our library and see if you have any better luck
nope! updating the library solved it for us
