Please help, timer issue
Hey guys, I’m a fisrt time coder for this year, and I need some help with my code. I have a timer which I can get working in normal mode, where the joysticks control the robot, but I cannot get it to read in autonomous mode. Here is the code from my user_routines_fast file. Thank you very much in advance!
* FILE NAME: user_routines_fast.c <FRC VERSION>
* DESCRIPTION:
*  This file is where the user can add their custom code within the framework
*  of the routines below.
* USAGE:
*  You can either modify this file to fit your needs, or remove it from your
*  project and replace it with a modified copy.
* OPTIONS:  Interrupts are disabled and not used by default.
#include <timers.h>
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "user_routines.h"
#include "user_Serialdrv.h"
/*** DEFINE USER VARIABLES AND INITIALIZE THEM HERE ***/
unsigned char t25msDelay;
unsigned char t100msDelay;
unsigned int secondCount;
* FUNCTION NAME: InterruptVectorLow
* PURPOSE:       Low priority interrupt vector
* CALLED FROM:   nowhere by default
* ARGUMENTS:     none
* RETURNS:       void
* DO NOT MODIFY OR DELETE THIS FUNCTION
#pragma code InterruptVectorLow = LOW_INT_VECTOR
void InterruptVectorLow (void)
  _asm
    goto InterruptHandlerLow  /*jump to interrupt routine*/
  _endasm
* FUNCTION NAME: InterruptHandlerLow
* PURPOSE:       Low priority interrupt handler
* If you want to use these external low priority interrupts or any of the
* peripheral interrupts then you must enable them in your initialization
* routine.  Innovation First, Inc. will not provide support for using these
* interrupts, so be careful.  There is great potential for glitchy code if good
* interrupt programming practices are not followed.  Especially read p. 28 of
* the "MPLAB(R) C18 C Compiler User's Guide" for information on context saving.
* CALLED FROM:   this file, InterruptVectorLow routine
* ARGUMENTS:     none
* RETURNS:       void
#pragma code
#pragma interruptlow InterruptHandlerLow save=PROD /* You may want to save additional symbols. */
void InterruptHandlerLow ()
  unsigned char int_byte;
  if (INTCON3bits.INT2IF && INTCON3bits.INT2IE)       /* The INT2 pin is RB2/DIG I/O 1. */
    INTCON3bits.INT2IF = 0;
  else if (INTCON3bits.INT3IF && INTCON3bits.INT3IE)  /* The INT3 pin is RB3/DIG I/O 2. */
    INTCON3bits.INT3IF = 0;
  else if (INTCONbits.RBIF && INTCONbits.RBIE)  /* DIG I/O 3-6 (RB4, RB5, RB6, or RB7) changed. */
    int_byte = PORTB;          /* You must read or write to PORTB */
    INTCONbits.RBIF = 0;     /*     and clear the interrupt flag         */
  }                                        /*     to clear the interrupt condition.  */
  else
    CheckUartInts();    /* For Dynamic Debug Tool or buffered printf features. */
* FUNCTION NAME: User_Autonomous_Code
* PURPOSE:       Execute user's code during autonomous robot operation.
* You should modify this routine by adding code which you wish to run in
* autonomous mode.  It will be executed every program loop, and not
* wait for or use any data from the Operator Interface.
* CALLED FROM:   main.c file, main() routine when in Autonomous mode
* ARGUMENTS:     none
* RETURNS:       void
void User_Autonomous_Code(void)
  /* Initialize all PWMs and Relays when entering Autonomous mode, or else it
     will be stuck with the last values mapped from the joysticks.  Remember,
     even when Disabled it is reading inputs from the Operator Interface.
  pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
  pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
  relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
  relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
  relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
  relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
           /* Add your own autonomous code here. */
//autonomous_mode =1; // take me out
if (secondCount <= 15){
printf("Going %d", secondCount);
printf("Elapsed Time(s) = %d
",secondCount);
pwm01 = 254;
pwm02 = 0;
        Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
* FUNCTION NAME: Process_Data_From_Local_IO
* PURPOSE:       Execute user's realtime code.
* You should modify this routine by adding code which you wish to run fast.
* It will be executed every program loop, and not wait for fresh data
* from the Operator Interface.
* ARGUMENTS:     none
* RETURNS:       void
void Process_Data_From_Local_IO(void)
  /* Add code here that you want to be executed every program loop. */
if (PIR1bits.TMR1IF)
PIR1bits.TMR1IF = 0;
TMR1H = 0x85;
TMR1L = 0xED;
if (t25msDelay > 3)
rc_dig_out03 ^=1;
t25msDelay=0;
if (t100msDelay >9)
rc_dig_out04 ^=1;
t100msDelay = 0;
secondCount++;
",secondCount);
t100msDelay++;
t25msDelay++;
* FUNCTION NAME: Serial_Char_Callback
* PURPOSE:       Interrupt handler for the TTL_PORT.
* CALLED FROM:   user_SerialDrv.c
* ARGUMENTS:
*     Argument             Type    IO   Description
*     data        unsigned char    I    Data received from the TTL_PORT
* RETURNS:       void
void Serial_Char_Callback(unsigned char data)
  /* Add code to handle incomming data (remember, interrupts are still active) */
The simple answer is that Process_Data_From_Local_IO() isn’t ever being called from your User_Autonomous_Code() loop, so your timer isn’t ticking.
The more complex answer is that most people setup their timers to operate as interrupts in InterruptHandlerLow (), so they happen regardless of what loop you might be caught in, a la, http://www.ifirobotics.com/docs/timers_white_paper_2004-jan-14.pdf
