package frc.robot;
import edu.wpi.first.cameraserver.CameraServer;
import edu.wpi.first.wpilibj.GenericHID.Hand;
import edu.wpi.first.wpilibj.Spark;
import edu.wpi.first.wpilibj.SpeedControllerGroup;
import edu.wpi.first.wpilibj.XboxController;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import edu.wpi.first.wpilibj.Timer;
// Setting up all the PWM Channels
private static final int kRearRightChannel = 0;
private static final int kFrontRightChannel = 1;
private static final int kRearLeftChannel = 2;
private static final int kFrontLeftChannel = 3;
private static final int kWinch = 4;
private static final int kArm = 5;
private static final int kIntake = 6;
private static final int kLauncher = 7;
private static final int kIndexer = 8;
private static final int kColorwheel = 9;
private static final int kJoystickChannel = 0;
private XboxController m_xbox;
// Setting up subsystems
Spark indexer = new Spark(kIndexer);
Spark winch = new Spark(kWinch);
Spark arm = new Spark(kArm);
Spark intake = new Spark(kIntake);
Spark launcher = new Spark(kLauncher);
Spark colorwheel = new Spark(kColorwheel);
// Setting up driving motor contorllers
Spark frontLeft = new Spark(kFrontLeftChannel);
Spark rearLeft = new Spark(kRearLeftChannel);
Spark frontRight = new Spark(kFrontRightChannel);
Spark rearRight = new Spark(kRearRightChannel);
SpeedControllerGroup m_left = new SpeedControllerGroup(frontLeft, rearLeft);
SpeedControllerGroup m_right = new SpeedControllerGroup(frontRight, rearRight);
private DifferentialDrive m_drive = new DifferentialDrive(m_left, m_right);
// Auton
private double startTime;
@Override
public void robotInit() {
//Vision setup
CameraServer.getInstance().startAutomaticCapture(0);
CameraServer.getInstance().startAutomaticCapture(1);
// If the motors are inverted. DO NOT mess with it until it has been tested.
m_left.setInverted(true);
m_right.setInverted(true);
//Setting up the drive train and Xbox controller
m_xbox = new XboxController(kJoystickChannel);
@Override
startTime = Timer.getFPGATimestamp();
@Override
double time = Timer.getFPGATimestamp();
double runTime = time - startTime;
System.out.println(runTime);
double indexerPower = 0.0;
double launcherPower = 0.0;
double leftPower = 0.0;
double rightPower = 0.0;
if (runTime > 10) {
indexerPower = 0.0;
leftPower = 0.0;
rightPower = 0.0;
else if (runTime > 6) {
indexerPower = 0.0;
leftPower = 0.5;
rightPower = 0.5;
} else {
indexerPower = -1.0;
launcherPower = 0.8;
leftPower = 0.0;
rightPower = 0.0;
indexer.set(indexerPower);
launcher.set(launcherPower);
m_drive.tankDrive(leftPower, rightPower);
//Remote Controls
@Override
// Left joystick is for the left side
// Right joystick for the right side
m_drive.tankDrive(m_xbox.getY(Hand.kLeft)*3/4, m_xbox.getY(Hand.kRight)*3/4);
//public boolean isRunning(){
//boolean running = true;
//while(running){
//subsystem.set(0.0);
//DPAD TEST
if(m_xbox.getPOV() == 90){
colorwheel.set(-1);
if(m_xbox.getPOV() == 180){
colorwheel.set(1);
if(!(m_xbox.getPOV() == 90)||(m_xbox.getPOV() == 180)){
colorwheel.set(0.0);
//Left Stick
//Right Stick
if(m_xbox.getAButtonPressed()){
launcher.set(1);
if(m_xbox.getAButtonReleased()){
launcher.set(0.0);
// Left bumper
// Left trigger
if(m_xbox.getBumper(Hand.kLeft)){
indexer.set(-1);
if(m_xbox.getTriggerAxis(Hand.kLeft)!=0){
indexer.set(1);
if(!(m_xbox.getBumper(Hand.kLeft)||m_xbox.getTriggerAxis(Hand.kLeft)!=0)){
indexer.set(0.0);
// Right bumper
// Right trigger
if(m_xbox.getBumper(Hand.kRight)){
intake.set(-0.5);
if(m_xbox.getTriggerAxis(Hand.kRight)!=0){
intake.set(0.5);
if(!(m_xbox.getBumper(Hand.kRight)||m_xbox.getTriggerAxis(Hand.kRight)!=0)){
intake.set(0.0);
// A button
// B button
if(m_xbox.getBButtonPressed()){
winch.set(1);
if(m_xbox.getBButtonReleased()){
winch.set(0.0);
// X button
// Y button
if(m_xbox.getXButton()){
arm.set(-.45);
if(m_xbox.getYButton()){
arm.set(.45);
if(!(m_xbox.getXButton()||m_xbox.getYButton())){
arm.set(0.0);
That is our code, but we have tested so much with it and can’t seem to fix the problem at all.
