I keep getting error :Error at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:244): ERROR Unhandled exception: java.lang.RuntimeException: Code: -1029. HAL: Resource already allocated at [edu.wpi.first.wpilibj.hal.PWMJNI.allocatePWMChannel(Native Method), edu.wpi.first.wpilibj.PWM.initPWM(PWM.java:117), edu.wpi.first.wpilibj.PWM.<init>(PWM.java:134), edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java:35), edu.wpi.first.wpilibj.Talon.<init>(Talon.java:51), org.usfirst.frc.team5713.robot.Robot.robotInit(Robot.java:25), edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:242)]
Joystick mXboxController = new Joystick(0); // this will drive the robot
Joystick controlStick = new Joystick(1); // this will be for function of the robot such as toggle the conveyor belt and etc.
Talon frontLeft = new Talon(3);
Talon frontRight = new Talon(2);
Talon rearRight = new Talon(0);
Talon rearLeft = new Talon(1);
public void robotInit() { // this code will be ran each time we power on the robot
mXboxController = new Joystick(0); // depends on the usb connected to computer
rearLeft = new Talon(0);
rearRight = new Talon(1);
public void autonomousInit() { // triggers when we enter autonomous
frontLeft.enableDeadbandElimination(true);
frontLeft.set(-1.0);// dont forget to change speed to an int value -1.0 is full reverse and +1.0 is full forward also for foward on the y value -1 this may vary REMEBER!!!
rearLeft.enableDeadbandElimination(true);
rearLeft.set(+1.0);
frontRight.enableDeadbandElimination(true);
frontRight.set(-1.0);
rearRight.enableDeadbandElimination(true);
rearRight.set(+1.0);
public void autonomousPeriodic() { // this code runs periodically in autonomous
while (isAutonomous() && isEnabled()) {
public void teleopInit(){ // This triggers every time we enter telop mode.
mXboxController = new Joystick(0); // the number within the parathesis depends on the controllers usb order always check
while (isOperatorControl() && isEnabled()) {
if(mXboxController.getRawButton(8)){
frontRight.set(1.0);
} if(mXboxController.getRawButton(7)){
frontLeft.set(1.0);
if(mXboxController.getRawButton(5)){
rearLeft.set(-1.0);
} if(mXboxController.getRawButton(6)){
rearRight.set(-1.0);
Timer.delay(0.01); } } // this will constantly update motors and speed controllers periodically
public void testPeriodic() {
LiveWindow.run(); // launches the smartdashboard that allows us to see inputs and out puts to the robot
