Pneumatic Fittings
Last night we came to the realization that no piston fittings came in the KOP like they usually did…so off I went in search for some.
After a couple of hours of CD searching and distributor locating that resulted in dead ends, I finally just Google-searched the part number. Whatdya know, the first link gave me what I needed (woot for Google :smiley: ). So for any of the teams who are new to pneumatics, here’s a bit to save you some frustration. Perhaps this could form into a sticky if enough info gets posted.
Here’s a thread that tells where to get cheap fittings – though you need to email them if you want to get them within a few days rather than a couple of weeks (7-10 days processing + shipping time).
There’s a thread around here that lists all of the part #'s for the fittings that typically come in the KOP. For the life of me I can’t find it…so for now here’s a link to purchase the pneumatic elbows that fit into the smaller pistons:
p/n KQ2L07-34s
Thanks in advance for any extra info that gets posted!
Thanks for posting this! No one answered me before when I posted this topic asking for help!!
Other commonly needed pneumatic parts.
Tee fitting:
White: http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=4990150&MPN=KQ2T07-00&R=4990150
Basic Black: http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=4990926&MPN=KQT07-00&R=4990926
Straight connector:
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=4990123&MPN=KQ2H07-00&R=4990123
Flow control valves:
http://www.alliedelec.com/Images/Products/Datasheets/499-1574.pdf
A few variations available here, e.g., you might want to meter the flow into an actuator vs. out of an actuator.
[FONT=Verdana]Last year’s was a: NAS2201F-N01-07S[/FONT]
(This translates to: 1/4" elbow, meter-out, one-touch fitting, NPT, 1/8"port, 1/4" tubing, with seal)
Straight screw fitting:
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=4990012&MPN=KQ2H07-35S&R=4990012
The screw fittings required differ based on the hole in your cylinder, for example, the Clippard storage tank has a 1/4" NPT port, while a typical actuator might use 1/8", and the Bimba rotary actuator requires a tiny connector.
It looks like your source only stocks the 24V coils (we need 12v) on the SMC solenoids, but you can order them from the catalog: http://www.alliedelec.com/Catalog/pf.aspx?FN=1516.pdf
Last year’s double solenoid was a: SY3240-6H-S
(This translates to SY3000 series, 2-position single action, base mounting, 12VDC, L-type plug connector, surge suppressor)
The single-action solenoid was a: SY3140-6H-S
Each SMC solenoid also rquires a base: [FONT=Arial]SY3000-27-1T
[/FONT]
Parker Plug Valve:
http://www.parker.com/portal/site/PARKER/menuitem.bb22d5a82bbb5b147cf26710237ad1ca/?vgnextoid=a2d9b5bbec622110VgnVCM10000032a71dacRCRD&vgnextfmt=EN&vgnextcatid=10735&vgnextcat=PV609%20%20PLUG%20VALVE%20-%20FEMALE%20PIPE%20ENDS&vgnextdiv=687547&vgnextpartno=PV609-4
Use “locate a distributor”
Nason Pressure Switch:
Call (800) 229-4955 to order part#[FONT=Calibri][size=3]SM-2B-115R/443
[/size][/FONT]
Clippard air storage tanks:
http://www.clippard.com/store/display_details.asp?sku=AVT-32-16
1/4" Tubing:
e.g., http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=4991634
In general,
Look for 1/4" tubing fittings.
Solenoids need to have 12v activating coils.
We keep some pneumatic info on our team website at: http://www.team358.org/files/pneumatic/
Also the Fluid Power Education Foundation - Pneumatic System education
Here are the Kit suppliers:
Bimba Manufacturing - Special order pneumatic cylinders
Clippard Instrument Laboratory, Inc - air storage tank
Freelin Wade - Pneumatic tubing (50% off, 888-373-9233)
HPE Automation - Teflon Tape
Lord Corporation - Vibration isolaters
Monnier Corp.- Regulator & bracket
Nason Company - Pressure switch
Norgren Regulator - gauge, relief valve
SMC Pneumatics, Inc.- Pneumatic fittings
Festo - Single-action solenoid
Thomas Industries - Air compressor
Wika Instruments - Pressure gauges
Parker - brass fittings
Hi everyone,here you could find pneumatic fitttings(one touch fittings) with competitive prices. www.pneuflex-fittings.com We are designing new styles to suit all kinds of requirment.
