Can someone tell me how to program 2013 Pneumatic and set it up?
Also, how do you program ultrasonic sensors?
Pneumatic & ultrasonic programming examples come with the LabVIEW installation.
Note: Not all ultrasonic sensors are the same, so different one’s will code differently and some won’t work directly with our system.
Look under the LabVIEWGetting Started window -> Support -> Find FRC Examples…
Then look in the pneumatics or sensors folder for example programs that can also be run to test that your hookups are correctly done.
