how do you wireall of the pneumatics
First off, you need to be more specific, but I hope this helps.
The pnuematic pump and the solonoids will need to be powered through Spikes. The pump can only be on when the pressure switch is off (open). This is done in the programming.
The info about the pnuematic parts are in the pnuematics manual: http://www2.usfirst.org/2003comp/pneumatics_manual_2003.pdf
The info about wiring the spikes is at: http://www.innovationfirst.com/FIRSTRobotics/pdfs/SpikeBLUEUsersManual.pdf
RTFM then post specific questions…
[quote]*Originally posted by ark_1230 *
**First off, you need to be more specific, but I hope this helps.
The pneumatic pump and the solenoids will need to be powered through Spikes. The pump can only be on when the pressure switch is off (open). This is done in the programming.
A bit more specific question:
Can someone direct me to an information source for which relay to use to control the pump and is there code already in the default program to control it’s operation?
Thanks,
APS:yikes:**[/quote]
