Pneumatics Java Code Not Working
Hey all,
My team and I are trying to use our pneumatics. Only problem is none of it is working. When I try to run our code, we get a bunch of errors and stuff: https://pastebin.com/zyZKUPTf
Here’s our Robot.java code and our pneumatics class:
Robot.java: https://pastebin.com/3BQGuWM7
Pneumatics: https://pastebin.com/csHkhfCf
ANY HELP IS HUGELY APPRECIATED!!!
Is your PCM on? Is your compressor correctly wired up? Is your PCM connected to CAN?
With regard to your code, you rarely need to instantiate a compressor object. See the javadoc for the Compressor class.
Just instantiate your Solenoid or DoubleSolenoid and your compressor should start working in closed-loop mode.
Using Phoenix Tuner, can you confirm that the PCM is present, has the latest firmware and has a device ID of 0.
Also, maybe I misread, most of your code, including pneumatics, is commented out?
Also, make sure you have read and followed the Phoenix Documentation, especially for the PCM:
https://phoenix-documentation.readthedocs.io/en/latest/ch09_BringUpPCM.html
