Pneumatics Questions
-Are we allowed to use three cylinders? Do we order them directly from BIMBA/PARKER, or from a local distributor (same brand)?
-Are we allowed to use more than two Clippard air tanks? (Hint, hint: In our case, four…)
*Originally posted by RAWdealer59 *
**-Are we allowed to use three cylinders? Do we order them directly from BIMBA/PARKER, or from a local distributor (same brand)?
-Are we allowed to use more than two Clippard air tanks? (Hint, hint: In our case, four…) **
you can use 3 cylinders. FIRST has provided one cyl in the kit of parts(the 8" stroke, 1.5" bore parker piston) and you can order 3 custom cylinders from bimba/parker using the order form provided in the manual. you’re only allowed to use 2 clippard air tanks. i know, they’re really small, but thats what FIRST gives us and lets us use. good luck
