PneumaticsModuleType cannot be resolved to a variable
import edu.wpi.first.wpilibj.PneumaticsModuleType;
public class Drive extends Subsystem {
private static final int kLowGearVelocityControlSlot = 0;
private static final int kHighGearVelocityControlSlot = 1;
private static final double DRIVE_ENCODER_PPR = (2048.0 * 52.0 * 50.0) / (12.0 * 24.0); // For TalonFX internal encoder(2048 CPR)
private static  Drive mInstance = new Drive();
//Hardware
private final TalonFX mLeftMaster, mRightMaster, mLeftSlave, mRightSlave;
private final NavX mNavXBoard;
private final Solenoid mShifter = new Solenoid(PneumaticsModuleType.CTREPCM, 2); ...
Do you get this when you build or only intellisense? Can you post a screenshot of the window from “Wpilib: open project information”?
it gives like this.
Is your WPILib VSCode the latest version?
I think the red underline on the pneumaticsmoduletype import is the issue; if it imports correctly the type should resolve.
