If any PNW teams have any spare 14T or 38T gears, Team 2412 (the Robototes) needs two of each (we ordered the wrong ones )
Please PM me or respond to this thread if you can get them to us. Thank you!
What dp/bore?
3/8" hex ID (20DP)
There is a good chance we have these gears. I’m assuming the 14T is a motor pinion. What motor are you using it on? Falcon or cim/NEO? Or maybe 3/8" hex?
It’s not a motor pinion - it’s a steel 3/8" hex bore gear (20 DP).
I don’t think there are any 14T, 20DP, 1/2" hex bore gears. The bore is to large for that amount of teeth.
3/8", my bad.
That’s equivalent to the small cluster gear in a 12.75:1 toughbox series gearbox. (I have at least two, but I couldn’t get them to you any faster than AndyMark.)
Got it. The 38 tooth is still 1/2" hex though correct? We can check what he have in the shop tonight.
Yes, the 38 tooth is 1/2" hex (I double checked this time )
I’ll check, but I’d also reach out to NRG 948 – they have some spare toughbox minis, which should have the 14t ones
Okay, I know we have some of those around. I’ll have to have a look when I get to the school. I’m just hearing about this, but I’m the one who checked the order so I feel like this is probably somewhat my fault.
Thank you everyone for looking! We got a couple from 1899. Thanks!
