Point Calculator
Created an excel spreadsheet to help out with point analysis and game planning. Plug in variables such as cubes in vault, ownership time, teams that climbed, etc. and it gives you a net total. It does take power-ups into account, along with point differences between teleop and auto. Suggestions welcome
http://www.mediafire.com/file/b6a67m4955np7dv/PowerUP_Point_Analysis.xlsx
Thank you!
Very easy and good calc.
thanks for the file. we will look at this and give ya some feed back.
Thank you. Quick question on the Boost 3 points. Boost doubles the points for 10 seconds on both the scale and the switch. That is a total 20 pts additional on the points tallied in column G. So the max for K6 is 20?
I didn’t realize that. Thanks for pointing it out. I’ll fix it once I get the chance. Made the same mistake with boost 1/2
Fixed. New file
http://www.mediafire.com/file/80cg2vic56u5tv6/PowerUP%20Point%20Analysis%20v2.xlsx
If they are climbing they don’t get 5 for parking its either or (same for Levitate it counts as 30 not 5)
