[Poll] How much should the GDC change IR for 2021
[water game joke goes here]
One question is whether changing the ball to be more durable but the same size qualifies at “significant”? If FIRST wants to save money, they may want to make this change because they were going to run out of usable balls by the end of the season.
I picked significant, but wouldn’t be upset with major. While I get that HQ wants to leverage existing field elements, teams should have to seriously consider strategy and optimize mechanisms after kickoff. Things that might look like Team Updates won’t make this happen. TBH, I’d rather not have the 2021 season look like the 2020 post season that might have happened.
Seems like that could seriously nerf the game. Park in front of the upper/inner goal and just pump balls into the inner goal that your alliance members put in your input. I’m not sure you’d even need wheels! Not very exciting.
Ditch retroreflective tape or at least add some fiducial markers to the field. Please. Please. Please.
siiiiiiiiiiiighs in going back on his plan to make exactly one post in this thread
  • You need wheels to get off the installation line and get to the target zone.
  • 25 hang points is another 8-12 balls. You won’t want to leave that on the table. Which not just means wheels, but being able to do it with minimal dead time after folding up your high goal doohickey.
  • “We’ll sit here and make it so our partner can do X” is very rarely a winning strategy. Most rampbots or lifters in 2018 and 2019 floundered. The ones that were good always brought something more to the table, and could do it to a high standard. With fewer balls than we think out there on the field, a team doing this is just going to have to be mobile.
#walkerweightbonus2021
Scoring changes, to 2, 3, 4 for lower, outer, inner, or 2, 2, 3 for lower, outer, inner.
Makes low scorers more valuable and reduces the end game point weight.
A small weight allowance (+5 lbs) would encourage more teams living at the limit to try at least some form of modification and change. Without this, teams that already spent much effort getting their robot to function within the original limit are likely not going to be as motivated to rip all that apart to add new features compatible with revised game rules.
Offseasons permit this allowance all the time…including IRI.
If you want to encourage more spending and support of suppliers in 2021, then adding more weight budget would directly contribute to achieving that goal.
The only major change I want to see is that the name of the game is changed to Infinite Replay.
Ok, the wheels thing was a wee bit of hyperbole. :wink:
But it definitely could be worth specializing to get 3 pts on every one of your alliances’ balls. We did a similar thing (to a more limited degree) with 1982 during auton for IR.
We found that we and alliance parter 4499 had very similar autons, so we couldn’t both do them. So they kept theirs and we made a new 6-ball with 1982 who had been just dumping in the 1pt goal during auton.
Here’s our first practice run:
and we used it successfully in every elimination match.
What do you mean by this in the post-bag era?
[Insert immediate 500 likes for comment [water game joke goes here] followed by at least one laughing face]
The robot weight remains a build constraint regardless of how much time you have to pursue changes. I imagine a good many teams operate near that maximum weight, and such teams are not going to readily want to undo all of the things they did in 2020 to fit under the limit.
The GDC has mitigated time as a limiting factor via replay but money and weight still remain. If a team has some money to spend on upgrades and especially additions, the weight budget still remains a key roadblock for many. Relaxing the weight limit a small amount would incentivize changes without harming gameplay. Again, many offseasons employ this +5 allowance knowing teams like to add or change mechanisms after the season is done and try them out at offseason events. It gives teams the wiggle room to work on such things without stressing over fitting into the original weight window. Lacking the allowance, teams are more likely to not spend money and time on the effort.
I am presuming that the GDC will not be significantly changing the core gameplay elements of collecting shooting and hanging because that completely counters the whole point of replaying the game. If so, many are not going to want to change what works well. If what works well weighs close to the limit, that doesn’t leave any wiggle room for anything else the GDC might toss their way.
And I do think it is a noble goal to incentivize supporting suppliers without cruelly forcing it upon teams via wholesale game changes. A weight allowance means you can add more stuff to the robot if you want, which is an EASY, passive way to say “Hey guys it’s OK to work on your bots and spend more money and help these suppliers remain in business if you can”. I would think such a tactic would spread out the costs of supplier support among more teams willing to work with that extra weight budget. And who knows - maybe it would even convince some teams to try new mechanism upgrades that they felt would not fit within the original weight budget?
It’s a trivial change to make that could ease stress on teams, stimulate new creativity even in a replay scenario, and put more money in supplier pockets.
On the one hand, yes. On the other hand, it seems FIRST is right on the limit of what two people can lift safely. When the weight limit went up five pounds after off-board compressors were axed, bumper weight limits went down by the same amount.
Swap a BaneBots 550 for a RedLine where you didn’t really need the power, and that’s 5 ounces saved for under $20 (under $10, if you already had the appropriate pinion). Put a NEO 550 in instead, 7.9 ounces.
Or bring out the big firepower, ditch the four CIMs for four NEO or Falcon 500 motors, and save somewhere north of seven pounds.
TL;DR a team can totally throw suppliers a bone and find room for mechanisms without a weight change. It just means optimizing more than they may be used to, but now they have time and insight they aren’t used to.
I assume for a lot of teams, the concern on changing things might less so be making weight and more so spending money they may or may not have on changes that may or may not come, particularly when we’re unsure when the next time we’re gonna see the robot is too.
I think both are a factor. I know my old team for example who does not yet have a climber is precariously close to the weight limit. I could see an increase in the limit encouraging them to tackle new elements that without that increase they may otherwise not.
Firing power cells into the inner goal from point blank range would make it extremely difficult for more than one robot to sore at a time. As such, I would argue that the alliance in this scenario wouldn’t necessarily be stronger than an alliance of 3 dedicated scoring robots.
More than one robot scoring at the exact same time wasn’t all that common anyway, and from what I remember when it did happen a decent bit more balls bounced out than if just one was scoring. If the extendo-bot was quick enough with it’s dumping, I don’t think it would limit a shooter that much.
I can’t think of anything I’d be less in favor of than changing the game piece, and I very sincerely believe that isn’t going to happen. Just because Team A has money, access to their shop and robot, and the support of their community to meet, doesn’t mean that will be close to the standard for Team B this year. A lot of teams will likely not be able to compete at all if the game element is redone. Change the rules, change some scoring, sure. Make the Control Panel not a complete waste. Redo the stickers on the walls. But don’t change the balls.
