Possible FMS problems.
Yesterday we tested for all of these, we replaced all the connectors from the CRIO to the PD board, we tried shaking the CRIO to get it to reboot, we also tried the tapping on the reset, and pulling on the wires. I think what we will have to do next is test the PD board connections to the motor controllers and all of the breakers. We also put in two new vector motor controllers this week and our mentor also had us wire the fans to a 30 amp slot on the PD board.
Will this still be accesible when we aren’t connected to a field and still driving around? Thanks for the link, we will definitely use it!
I’m not sure if we are or not, we are using the standard clamshell for driving, we have the same dashboard as last year and it was fine last year. I will ask the programmer later if we are but I doubt it.
Highly doubt you guys are using SmartDashboard since your team uses LabVIEW. I think I recall seeing the regular dashboard when playing with you guys. So i don’t think what Raul said applies
The event log is created by the driver station application local to your PC, and stores the logs on your hard drive. If you’ve been using the same PC for a few years, it will take a long time to load each time (until you go to the logging folder and delete old logs, use the windows sort by date to do this as log file name patterns changed year to year)
I only really discovered this utility at our last event (Southfield week 1) where the awesome FTA used it to help us diagnose some on field problems, it’s very very helpful as it shows a graph of battery voltage, cpu/ram usage, and any errors that were sent. After getting comfortable with it, I was able to squash a few more issues from the viewing the logs.
Are you using any of the DIO connectors? I have seen instances where the +5V wire from the PWM cable will short intermittently to ground. This is normally seen when the White and Black wires are used for a Limit switch. The RED wire is cut and left hanging instead of being cut back and taped. The end of the wire will come in contact with the Black wire causing the 5VDC in the Digital Sidecar to turn off.
Canon,
You can use a multimeter to check for continuity between the frame and each output terminal of every speed controller with the power off. You will likely find a short on one of them if this is related only to driving. It is normal for motors to have some resistance (2k-10k) to frame as the brush dust builds up inside. It is not normal to have a reading under 100 ohms. I am thinking you are going to find a shorted wire(s) in one of those outputs. There are two things that are known shutdown issues for the cRio. That is the cRio tied to the frame with another path somewhere, or a simple short on the output of a controller. If you are using Jags, the short should show up as a fault on the Jag that is affected even without motion I think.
So the output from the vector to the CIM motors? we are running 4 CIM motors as well. So we need to put the hot wire to the output and the ground on the multimeter to the frame and if we get a reading of 100 ohms we need to replace the motor controller? or is it the wire from the PD board to the Vector? Thank you so much for your help!
Canon,
You need to check each Victor output screw to robot frame. The fans on the Victors are legal to be wired to the input terminals of the Victor to which they are mounted. They do not need to go back to the PD. Since you can only put one wire into a WAGO terminal, and it must be #18 or larger, wiring the fans to the PD is not practical. It is possible for metalic debris to enter a Victor in such a fashion that it will show a short in only one direction. However, that usually shows up in a very spectacular fashion.
I tested the output screws on each side, on one side I got .3 resistance, on the other .4, is this ok? I am also getting a 12.5 volt reading on the input to the victors. I’m not sure how to test to the frame. I connected one part to the screw and the other to the frame and get zero everytime.
Canon,
You put one meter probe on each of the output screws and one on a metallic part of the frame with the power off. You should read something higher than 2000 ohms. If you are reading the same value (~zero ohms) as when you touch the two probes together, then you have something shorted to the frame.
Ok, thank you for sharing you wisdom with us! I am relatively new to FRC and wiring in general, so if these questions seem very basic please bear with me. Why do we want to have 2000+ ohms from the frame to the vector output? Why does the short happen when it isn’t running through the frame? You do mean the drivetrain frame correct? here is the link to the multimeter we have, https://pioneers.berkeley.edu/wiki/How_to_Use_a_Multimeter from what you have said we do need to set it to the ohmmeter setting correct? So when we discover the short, what would be the proper steps to fix the problem and ensure it doesn’t happen again?
There was a team at Utah who lost communication sporadically during teleop, the mentor who I saw talking to the FTA about it looked like your profile picture. I also thought there was a team called the average Joes there, must have been mistaken.
Canon,
The short to the frame is an issue due to wiring errors, bare wire or lack of insulation. The 2000 ohms to frame is a normal condition with CIM motors that have been used for a while. The carbon dust worn from the brushes collects on the end bell of the motor inside and causes some leakage currents. When they get below 2000 ohms I start to worry. I speak to the drive train because you seemed to indicate the issue occurs only when driving. On the meter you show, if you set it to the position just below ohms, it will beep when you have a low resistance connection. If you find anything that beeps when one probe is connected to the frame, you have a serious problem.
I do believe we located 1/2 of the problem. I did the tests with the multimeter and it was fine, I then turned on the robot and began checking the converter for the radio, when I did I heard this high pitched whining noise, and I noticed this happened when I tugged on the Wago for the converter on the PD board. I could cause the entire robot to briefly shut off by slightly tugging on the connector. When I checked the connector it was charred black around the wire, and when I pulled the wire out it was as if all of the individual strands had been saughtered together. I replaced the wago and pulled on it and it didn’t shut off. We then tried to run the robot, but got no communication or code, but it did when we tethered it to the clamshell. I then drove back and forth and when I went forward then jerked back the entire robot shut off, the main breaker had been tripped. I pushed the red button on it then tried to turn it back on and it wouldn’t turn on then I had to leave. It did this as well yesterday, and ever since then we hadn’t gotten any communication or code unless we are tethered? Any probable causes?
Has the radio been reset since competition??
Yes, I reset it and made sure it as in ap 2.
Canon,
What you describe is typical when the wire strands come out of the WAGO and contact the other polarity. What you are doing is shorting out the power supply on the PD. I would check that you have wired the WAGO correctly when you replaced it. If that is not an issue, then you may have killed the PD power supply. The only repair is a replacement.
