Post video of your first HAB3 climb attempt
#99
It says the video is unavailable…
#100
@TikiTech Looks like we won’t need to climb up your ramp :slight_smile:.
Hopefully we have it working without hitches by stop build.
Edit: This was the one the first climbing attempts. I meant to post the first lifting attempt as well but couldn’t find the videos.
#101
This is our more refined, but not yet perfected version of the four bar lifting our practice bot.
We still need to automate it a bit, but it works and were pretty excited about that.
It is driven 2 mini cims on a custom gearbox. The overall reduction including chain is about a 450:1.
#102
Are those the piston rods that extend out from the bottom of the chassis at the front and back? If so, is there anything to prevent bending of those piston rods?
#103
Nice approach… It will be great to watch in person!
I agree with @philso you should look into supporting those cylinder rods.
Rods do not like lateral stresses and I think rope won’t qualify. :grinning:
Not sure how much iGus rods you have from KOP’s but those worked very well for our HP system.
Aloha
#104
Here’s a video of our our first successful in-match HAB3 assist using the ramp system on our robot. This was at our Week Zero Competition this past Saturday.
Ramp bots probably won’t work and here’s why
#105
And someone told my that a ramp bot was not possible. That’s awesome. Glad to know I was right. Great job!
#106
The RoboBees would like to join the fun.
#107
Whoa, that’s insanely quick. Really bringing the heat to Chesapeake. Looking forward to seeing you all at Owings Mills.
#108
https://youtu.be/0uWIUV9PvM0
Our first (slow) climb.
Not sure how to make the video show up
#109
We had posted our climb teaser here:
It was not our first attempt, so didn’t know if should be in this thread, but here it is.
#110
Got our time down to about 7 seconds.
#111
Really digging all these videos
#112
Not our first but this was taken at week 0 in Nevis MN. Our all female team 3134 the Accelerators of Cass Lake MN are showing off their RP potential. We are going to be climbing at the Lake Superior regional.
#113
Not our first attempt, but the only one i have on film.
#114
I remember learning a lot about how to use a rack and pinion for climbing from your 2016 design. How is this version for pushing down different since you don’t have the tube to keep the “rod” enclosed/straight.
#115
Hopefully this cad model helps clear it up.
Nothing special, one side rides against a delrin block with a groove cut in it, the other is supported by the pinion gear and a small delrin roller. 775pro on a VP @25:1 Aluminum tubing is .75" Square .125 Wall Gear rack is drilled and tapped 8/32 every 3 inches to attach to the aluminum tube.
#116
I posted our first attempt earlier, here is our first successful L3 climb.
#117
Well done!
#118
Awesome climb, and I love how your arm goes around your elevator. Looks like an amazing robot!
