Post video of your first HAB3 climb attempt
#119
Actually our second attempt, nobody got video of the first one, we didn’t expect it to go right up I guess
#120
Love the 1619-esk arm!
#121
Here are our first climbs.
#122
The fact that this looks like your bot is, “Blasting off,” is absolutely perfect. Awesome job!
#123
This is my favorite of all the HAB level 3 climbs I’ve seen so far.
#124
get it? :wink:
#125
that’s a plane and simple way to do it.
#126
Not mine, likely not a first, but here’s a link to 2992’s HAB3 climb:
#127
https://www.chiefdelphi.com/uploads/default/original/3X/0/9/093755d028078945a796c7669d93c3d4d619e920.MOV Surprisingly enough, our very first attempt was successful. The tip near the end was the result of an easily preventable driver error, but otherwise it was very successful.
#129
But the save before it tipped is the main concern
#130
Not our first attempt, but a pretty rough one.
#131
Our second attempt, still needing a lot of drivers practice.
#132
I really like all of these manipulator elevator + stilt designs that a lot of teams have converged on, they work really well!
#134
Is your team still planning on using the four bar mechanism?
#135
We are still planning to use a four bar, but have no footage of it working yet because we are so far behind schedule with our build this year.
#136
Not our first successful climb but it’s definitely the most polished. Looking forward to climbing week 2!
https://youtu.be/8qkKvlAWu4M
#137
How heavy are these cylinders? We’re looking to add something like this between events and have ~20lb to spare.
#138
They look a lot like the same ones we use. So ~5 Lbs each. Not exactly the best power to weight ratio…but they do work.
#139
I saw somewhere they’re using 2" bore 24" stroke cylinders – just to confirm, that’s what you’re using as well? Because I imported the STEP into CAD and made the material stainless steel, and got ~30lbs (was really hoping that wasn’t right).
#140
We are indeed using 24" stroke, 2in bore Stainless Steel Bimba Cylinders.
