Power Distribution Panel vs Power Distribution Hub Port Numbers
Hi everyome,
If you have the new PDH from Rev, am I correct in my understanding that you can use all 20 40A ports as you see fit? While if you are stuck with the PDP, you only get 16 40/30A ports?
That is correct. There are no restrictions on using all the ports on the REV PDH.
That’s really surprising to me.
In a year of epic supply chain issues and delays, penalizing teams that can’t get the newest hardware which boosts your max number of motors by 25% while also allowing easy powering of 12V peripherals like processors or cameras without resorting to sketchy USB battery packs and COTS connectors seems like a mistake.
Strictly speaking, R619 doesn’t prevent you from putting REV 40A breakers in the PDP. It might be disallowed via the connectors rule, R623; a Q&A is in order here…
remember just because you can, doesn’t mean the battery will like you. or the radio…or the RoboRIO. the last 2 hates brown out.
