Power Up Refrence Sheet
Linked to is a reference sheet for FRC 2018 Power UP. My team previously had a similar diagram for 2017 Steamworks, so I decided to make one for this year. It is intended to be printed on a 11"x17" paper.
https://goo.gl/pzLfPT
I saw the points you get for tele-op owning the switch or scale is 2+2p/s, but that’s only in boost or autonomous, not in regular tele-op…
Nice! Noticed something strange here: on the sheet, having a power cube in the vault is worth 5 points. It says 2 + 2 p/s on the sheet. May want to fix that.
From the manual:
Power Cube in Vault: 5 points (Table 2-2)
Thanks to Dennismast4481 and Mgineer, current version should be accurate and slightly better-worded.
