Powering the Robot From the Battery Charger
Is there any reason that running from the charger would be more advantageous or convenient than plugging in the battery?
That said, I don’t know about safety concerns, since I’ve never known anyone to bring up this idea.
(Edit: advice given wrt FRC, not FTC)
If you connected the robot to a charger, I am fairly sure you would draw too much current and burn out the charger. The charger is designed to deliver a few amps while running robots can draw a hundred amps.
I think the question comes down to how much are you trying to run?
If it is just the electronics to make sure everything is working, or running a free spinning motor, you may be OK, but you could run out of supply amps in a hurry.
The other thing to “strongly” warn about. There are parts of the electronics that will handle reverse polarity but NONE of the speed controllers do (jag, victor, talon) do. If someone clamped the charger to the supply terminals backwards and “poof” there they go. Really easy to do.
The battery connectors will not allow that to happen, so I would recommend just using the battery, or use a dedicated bench supply rather than the charger. And if using a dedicated bench supply use the Anderson power connectors so no backwards polarity can happen. Speed controllers are expensive (we had to replace 5 last year due to a sleep / sick student trying to rush the electrical without a double check from someone else before powering things up).
If you are just running the electronics and no motors, a good wall plug 12 volt power supply would be a good alternative to using the charger.
Also if just running the electronics, the battery will supply power for a long time before needing to be charged again.
Randy
Don’t every try and power the robot off of the charger! Chargers output voltages significantly over* the 12-13v that the battery supplies and are rarely rated for enough amps to power more than the control system.
*Some chargers spike up to more than 20v.
Bottom line: Powering a robot off a charger is a bad idea.
Looks like this is for FTC instead of FRC. However, I still would advise not to use the charger to power the entire robot. If you’re just powering the controller you might be fine, but add in a motor or more and all bets are off.
No.
A battery charger is not simply a DC power supply. Battery chargers typically contain advanced circuitry to measure the current status of the battery and adjust the electric current available. Batteries typically charge at their fastest rate when mostly depleted, then slow down as they approach full, then provide minimal trickle-charge current to keep the batteyr topped off when its full.
You will likely get unpredictable results attempting to use it as a power supply.
Also, the typical peak output current of a FRC battery charger is way under-powered for running a FRC robot. Most chargers can only put out a few amps at most, and a FRC robot can and do draw hundreds of amps for brief periods of time.
Thanks everyone!
I’m trouble shooting our FTC robot. It seems the NXT is working (ROBOTC sees it and can make it beep), I have the motor controller configured in the PRAGMA, the controller power LED is on, and the motors run with direct DC, but the motors are not running when under program control. Ive tried the simple sample programs and none of them work either. I’ve looked at it for about an hour and as a last resort I’m recharging the batteries. They’ve been charging for over an hour now.
UPDATE: Batteries are charged and the motors show as “running” in the NXT Device Control Display Debugger, but they’re not running.
For the VEX you could plug in the charger and battery at the same time to the controller but I really would not want to do that.
Instead I would get a power supply to act as the battery.
The Schumacher-branded chargers I have seen used for FRC robots test to see if they are connected to a battery by measuring the voltage at the terminals before turning on their output. Your robot should not have any residual voltage on it so the charger output will not turn on and no voltage will be applied to your robot. It is also likely that the starting surges of the CIM motors will cause the charger to go into current limiting mode and/or shut down.
GRT for years have been using 12 volt drills with the motor removed as power sources. Remove the motor and install long leads that you can use to power things with One drill battery will run 2 CIM motors. We use Anderson Power Pole connecters to hook things up. This gives you a variable voltage reversible polarity power source. You can add a fuse to both leadssince bioth can be positve. Walmart has their own line of 12 volt drills for 20$.
F,
It sounds like the motor controllers are not getting power or the controller is not being addressed properly. Power wiring to the controllers are notorious for falling out unless the wire is carefully prepared and inserted.
As a new user, I have to ask if the controllers are connected to a working sensor port on the NXT brick and that they are properly looped if you are using more than one. It is possible that the cable between the first controller and the NXT is bad.
You’re not a new user, Al :slight_smile:
You’d be much better off, powering you robot off a switching PSU or an ATX psu.
An ATW PSU will typically have over-current protection and can typically handle over 20 amps at 12 volts. However, don’t expect to run CIMs (CIM, MiniCIM and BAG). The BAGs draw up to 40 amps at stall!
I believe the batteries fast-charge at 3A/hr. I think the bridge consumes 1 or 2 amps, by itself. Plus, you have a cRIO, DS, and other components, like a coprocessor. So, you’d probably see magic smoke from that $100 charger you saved up for!
---------AAAHHH!!! You’re an FTC, not FRC. My bad. I’ll leave that up because that would be useful for FRC teams---------
Again, just get an ATX PSU and hack it so it is always on. That only requires a paperclip. Battery chargers are not meant for powering things. They are meant for charging batteries! Don’t ask up why you got magic smoke if you used a battery charger to power the robot.
This is what you aree probably looking for, and costs less than a good FRC charger. (I don’t know what FTC uses)
Ether, just testing to see who picked up on that. You pass!
I should have mentioned that it is never a good idea to power anything from a battery charger, particularly smart chargers. These devices generally test to see if a battery is connected and then will alternately turn on and off to supply current and then test for terminal voltage changes. In any case, the amount of current the charger can deliver is generally much, much less that that delivered by the same battery. In the case of the FRC battery, the charger is limited to about 6 amps max while the battery can deliver 100 times that amount when fully charged. In the case of the FTC system, the charger may be designed for NiMH batteries or the old NiCD and in either case, the charge voltage may just exceed the motor controller, it may open a fuse in the charger or it may just permanently damage the charger, controller or both. A 20 amp, 12 volt power supply might be able to run the motors but don’t be surprised if the start current causes even that larger charger to shutdown on over current. An FTC motor as I remember is about 7 amps stall current.
You need one of these DC 12V 10A 120W Switch Power Supply: http://www.amazon.com/gp/product/B007C055BK/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1
Or a 30A version DC 12V 30A 360W Switch Power Supply: http://www.amazon.com/SUPERNIGHT-Switch-Power-Supply-Switching/dp/B008HARHN8/ref=pd_sim_hi_1
you would want to wire up a three pronged plug extension cord to the AC in & ground.
Most battery chargers attempt to be a constant-current source and make no effort to regulate their voltage. They let the battery do that by taking the current until the voltage drops down to the level of the battery. The charger watches that voltage to tell when the battery is charged.
With no battery there, the voltage is likely to be quite a bit higher than you would expect for a “12” volt charger.
And the circuitry in smart chargers will further compound that. Good ones will recognize there is no battery attached and shut down.
The DC regulation on many chargers is also poor. They are often puslating, unfiltered DC and could damage sensitive electronics.
Don’t ever attempt to charge a battery while it’s attached to the robot (or other device.)
Does anyone know whether or not the above cautionary advice also applies to charging installed auto batteries?
I think it would because a similar technology is used. That would make the charger think the battery is charging, when it isn’t, which could possibly lead to a battery problem, like an explosion in extreme cases!
Also, just get a good atx psu. They can handle tons of amps and can be purchased for very little money! The power output is so high that loading it down would give you the bang for the buck :D.
One nice thing about ATX PSUs is that they have 5v and 3.3v rails built in, which can be useful for powering/testing different parts of the robot without using the 12v supply. Also, they are actively cooled, so while you will have a space-heater, it won’t overheat way too easily.
Also, the regulation in ATX power supplies is very precise. You don’t want to feed 12v2 to the mobo. You want a much higher precision than that, e.g. 12v01! That can eliminate some variables with voltage surges when you are testing or finding a problem.
Check this out, and also have a crack at the reviews!
A 1000-2000 watt supply with many powerful 12v rails is what every team should try to invest in, especially when you can get a decent one for about $100 and a fancy one under $200!
Thats the strangest thing i have seen, a computer power supply for external use? Im guessing for use in a Test Bench or something similar.
Ether,
Are you asking about the charging system in your car? Modern vehicles use an electronic form of battery charging. In older cars, they used stepped resistors to regulate charge current. The alternator output voltage is controlled to provide something higher than the terminal voltage on the battery. Typically some where between 14 and 15 volts. I read a paper a few years ago that stated the vehicle electrical system is one of the most harsh environments encountered in modern electronics. Power supplies vary from 7-8 volts to more than 18 volts and noise and various other transients even higher than that.
Cheap, line operated, automotive chargers simply rectify the output of a transformer and apply that to the battery. Some may have switched resistors to limit charge current. Smart chargers do a whole lot more.
